Grinding sound on low gears ...
45 views 4 replies 3 participants last post by  EBBO
#1 ·
my bike has done only 6000 kms and there seems to be a grinding noise while the bike accelerates on low gear, especially on first and second gears. Any idea what this could be ? This is not something which started recently, its been with the bike since day 1.
Since there is no authorized dealer I have not been able to get rid of it yet.
Any ideas ?
@esq'z me ,
#2 ·
Put it on a rear wheel stand. Rotate the wheel and check the chain for tight spots or kinks. Feel the wheel for roughness in the bearings. Run the bike in gear, possibly while dragging the rear brake, to listen for a source of the sound.
Only in 1st and 2nd gear ?? Or you just can’t hear it in higher gears because of wind noise ?
#4 · (Edited)
Hi, yes it is heard only while accelerating in first or second gear. Its not from the engine since there is no noice when the bike is throttled while in neutral. You are right, it has to be from the sprockets or chain, Shall do what you asked and get back to you today.
