1 - 1 of 1 Posts
Ok, the problem is with the headlights, everything works fine untill you put main beam on or flash, the high beam stays on untill you switch off the ignition!
I have taken the dimmer/ pass switch apart and cleaned all the terminals etc, and i have swapped the relay and it hasnt cured it! you can hear the relay click on but not off?
Its a UK model
Please help!
1 - 1 of 1 Posts
