It was time to clean my air filter on the 910R this weekend, well it was actually due a while ago but I finally got round to it Saturday afternoon.
Drained the tank, that $10 pump was the best thing I ever bought, drains all but a few drops of fuel from the tank which makes it so easy to remove even on your own....
Removed the side panels and started undoing the brackets. Dropped on of the bolts which proceeded to hide itself under the starter motor - never managed to do this before even after removing the tank many many times. I couldn't see the damn thing but Mrs Needle in a Haystack spotted it for me after she heard the swearing coming from the garage....
Drag a couple of drain hoses out of the way and poke a magnetic screwdriver in there, 2 mm too short to reach...
Swear some more and look from the garage for a longer one.
Repeat above as can't find it.
Ask the good lady if she can see it "You mean that one there in the top of the tool box"
More language I won't repeat.
Poke the longer screwdriver in, hear that clink as it attaches to the screwdriver :yo:
Start to withdraw and clink, I see it come out past the starter and fall down into never never land :jsm:
Swear some more, have a look and it's nowhere to be seem. Ask the good lady to see if she can spot it as I can't see it and it's not on the garage floor.
A few minutes pass and she can't see it either :wtf:, where the clucking bell is it ?
I get down on the floor under the water pump and shine my torch in. I can see something shiny amongst the black - thank the lord the WallyPower is black everywhere....
I sit up and contemplate draining coolant, removing hoses :blah::blah::blah: to get the water pump off.
:idea: I undo the two bolts that hold the pump there and pull it out a bit. Chink chink, the missing bolt hits the floor and doesn't roll under the car. :smoking:
The rest of the job went as per plan and she started right up once all back together with the cleaned and oiled air filter. :brutale:
Now if I'd only got on here before I started I would have know to ride down the road 10 mins and meet all those F4 boys for a pizza that same afternoon....
My wife and Mrs. Needle must be distant cousins.......
