1 - 20 of 25 Posts
Okay, I know there have been a couple of posts lately regarding the spacers inside the hub, but I am starting my own because of what I have just encountered with it and I don't want to muddy up anyone else's post.
Let's get the basics out of the way: I have a 2008 Brutale 910R. I bought it 6 1/2 years ago and it had 7500 miles (12,000 km) on it. I had the 7500 mile service and the 15000 miles service done on it at a dealer. From that point on, I have done all the maintenance on the bike - learning a lot along the way and very grateful to many of the members of this forum who helped me when I needed help. I first tackled my hub in early 2015 with 28,000 miles and found to my surprise that it had a 2010+ upgrade hub. From that point on, I made it a habit to check the hub at about every tire change which is at least once a year. Well, I had a couple of nail in tire situations which meant changing the rear tire more often than normal and I kind of stopped checking the hub (my bad, I know). So... all that's to say that I don't actually know when the last time I checked the hub (and when I say, "checked", I mean removed).
I needed to replace my chain a while back and had trouble getting the rear sprocket. Eventually it came in and I went about replacing the chain. My bike has 47,000 miles (75,000 km) at this point. I took the pin out of the nut on the left/chain side of the axle and the nut was loose - I felt it move when I removed the pin and I was able to unscrew it by hand. I immediately looked down between the sprocket carrier and the hub and I could still see space between the "hat" spacer and the hub, but I could tell it was closer than it should have been. Thankfully, it hadn't gotten close enough to get into contact with the hub/swing arm. I had just been reading some threads on here about other riders and that space running out and making contact, so I was relieved that I at least caught it before that happened.
Okay, so I took everything apart and the hat spacer and "floating" middle sleeve have worn grooves where the chain side sleeve had obviously been spinning independently. Both bearing sleeves looked good. I went to the dealer and it turns out that there are two "parts" of the hub assembly you can order separately and they are the hat spacer and the middle sleeve (you otherwise have to order the whole hub assembly). Obviously parts that seem to have a tendency to get worn. When they came in, the middle sleeve is noticeably heavier. It looks like the original sleeve was aluminum and the new one is steel. I would also like to point out to anyone who has not looked at the sleeves, the two sleeves that ride inside the bearings (on either side of the middle sleeve) have slight tapered edges - so their profile doesn't sit completely flush. - that's why it can wear a grove inside of the other spacers.
I inspected hub pretty thoroughly and it all looked okay outside of those two spacers. Everything is back together and I've put another 700 miles on it since
I can't believe I didn't tighten the nut the last time I had it off (and it had to have been at least a year or more, 8000 miles??), but I feel like that is the only explanation for what happened. I am also mad at myself for not keeping a better record so that I could at least know exactly how long ago and how many miles it has been since I last had it off.
Anyway, just thought I'd share my experience for what it is worth.
The attached images show the space between the hub and the hat spacer (worn on top, new on bottom) and the grooves worn in the two spacers. The middle spacer was worn severely on the left/chain side but also worn a tiny bit on the right/wheel side. I have also attached an image from when I originally took the hub apart years ago that shows two additional spacers with their tapered edges.
The sprocket side nut needs to be checked regularly to avoid this type of damage.
Before every ride I always give the nut a wiggle with my hand to make sure it is tight.
But saying that the sprocket side nut does not loosen with the set-up in my hubs.:wink2:
I am going to make that a habit myself!
I feel like you are trying to suggest something there...:grin2:
Just changed the back tyre and thought I'd service the hub. Sprocket nut was loose, spacers grooved. I'll be checking regularly before rides in the future.
Deano
@Deano: could you post year and model of bike so this post is useful to others.
But ....... but, but, but ........ If you have the sprocket side nut retention spring-clip in place, how on earth can the sprocket nut loosen? that spigot on the clip that engages in the hole should stop it rotating if properly fitted?
Now, this raises another point...... Although my bike has only covered 6k miles, it is an '05 so is now 13yrs old. To this end, I thought it might be prudent to check the hub grease, so just a few weeks ago stripped it down and re-greased it. On reassembling the bike, I took it for a little test ride. When I got home that spring-clip was hanging loose and just about to fall off. Because the spigot on the clip does not go all the way through and protrude through the spindle like it does on the wheel side (obviously to allow ease of use of the stand) it would seem it is quite easy to think it is seated in the spindle hole when it isn't really. Yet another thing to check ......
Firstly I never noticed my bike had disappeared from my avatar box or whatever it's called. It was there before they fucked with the site recently. It's a 2009 1078RR Brutale.
Secondly, I went to finish putting it all back together after the rear tyre/hub service and noticed it was a bit hard to push. Loosened the sprocket nut which I had torqued to 150nM (recommended 200nM) and it all spun free again. Stripped it all again to check but it would appear the wear in the spacers is now enough to lock it all up if the sprocket nut is torqued correctly. So now it's a wait for parts if they're available and a just nipped up sprocket nut, which seems to be its natural state. I have the 2010 updated hub after the original shit itself at 5000k. Bike now has 48000 on the clock. Hub was last serviced at 36288k when the last rear tyre was fitted. Hub was fine then so in the next 10000k those grooves definitely deepened.
Deano
The spring-clip thing is definitely easy to miss not getting in all the way.
In my case, the spring-clip was in fully, so the nut did not rotate. That's why the only explanation I can think is that I didn't tighten the nut correctly before putting the spring-clip in and over time it allowed the spacers to spin independently. I still can't believe I didn't tighten the nut before putting the spring-clip in...
Deano
Deano, glad you caught it before it did some damage! That was certainly a big relief to me.
Deano
Deano,this is the spacer I am talking about in the PM I sent you.
Have you still got one?
https://www.mvagusta.net/forum/attachment.php?attachmentid=452599&stc=1&d=1535514961
Folks, if the thing you are tightening your nut against wears due to whatever mechanism, then the nut will not stay tight because there is material loss. The nut is not necessarily turning. That which it it up against is eroding.
Very important to regularly check the sprocket side nut,you only have to wriggle it with your hand.
It only takes once to do damage to the centre spacer as it starts to spin and machine itself down reducing the overall length.
Good news Noel.
It's about time you serviced the hub too.:laugh:
How about if I wait until the hub hits 50,000mi?
My '66 Chevy has 327,000mi and has needed 2 bearings 1 in the alternator and the transmission
input shaft bearing broke it's cage
HaHa,I have No.1 in my bike 7 years old and 15000kms,I pulled it out a couple of months back,I shouldn’t have bothered,it was perfect,even the grease was good.:wink2:
OK, Mitch, I'll go for 50,000mi......
Found my sprocket side nut loose last week. Still have not opened up the hub, but my bike has over 20k miles, and I am thinking to go ahead and just replace the whole hub. Done some research on here, and its between Mitchy Hub and the Design Corse. They are both just as good and better/upgraded over the original from what I am reading. Seems pricing is the biggest decider, what do you guys think?
Here is a link to the Design Corse
https://www.designcorse.com/products/mv-agusta-upgraded-hub-dc?variant=4231848129
Contact Alex at GP Racing (Forum sponsor).
Alex has stock and is in your state.:wink2:
1 - 20 of 25 Posts
