I'm looking for the radiator support bracket (in the shape on triangle) no 100% what it called... as the one on mine, the rubber has came off..
Have you got a photo.If its the bracket I am thinking of it has 3 rubber grommets in it which you can replace quite easily.
So Kevin,you need the 3 grommets (No 26 in the picture) to fit bracket No 27,is that correct? If it is,like Donsy said take a sample of the grommet to any auto accessory shop and match them up.They are a standard type rubber grommet.
View attachment Document.pdf
Yeah.. I just need to replace the rubber? Ah, I didn't know about it.. I'll try to get it here.. thanks heaps!!
