1 - 20 of 107 Posts
Before I go and buy one. Does anyone have one they are willing to let go??
Discussion Starter #2
Disregard.. I bought the speedymoto one
Eh its ok.. I needed to buy one one anyways. But thank you!! We should get a beer soon.. When the world reopens
Reactions: Midnicrow
That's the place I got it from. Should be here Wendsday
Reactions: mitchy
I have the original rubber caps if you would like something more easily removed.
What caps are you talking about?
I got some aluminum pins a couple years ago. They work great. Use small tie wraps to keep in place. Should invest in cotter pins
:unsure:
I used some little bolts with a decent unthreaded area and a little lock nut each end.
Works well.
I only fitted them whilst waiting for the replacement aluminium pins in the post but they work so well Ive left them.
Discussion Starter #16
So I just got my speedy moto tool. How tight is thing suppose to fit on the nut? Its super tight... And yes I made sure I got the mv one.
Mine fits perfectly. It is not especially tight. Double check the part number.
It should slip in to the base and not rattle. You should not have to drive it home.
Reactions: gotojoe
Discussion Starter #20
I talked to someone from speedy moto and they said the mv nut itself might have too much material on it from the factory. They said its the tool eveyone uses.
Part number is 04-0203 as printed on the back
It does not slide to the base
1 - 20 of 107 Posts
