EDIT: got one. Pro Italia happened to have a used one laying around. Some small scuffs but they hooked me up on replacement wellnuts and bolts for it
Can't even order one from MV anymore. Add it to the list of parts that can only be found secondhand... :/
part number 80A099433, it's #11 in the linked diagram. Figured I'd check here before I look into ordering in case someone upgraded to a carbon one and happens to have the OEM one sitting around.
I'll also need 2 each of the screws (8A0090901), bushings (800091022), and the tiny plastic washers (800092882). If you have more, I'll buy more. 15 year old bike, those little rubber bushings are dry rotting and a bunch could use replacing, lest more things fly off while I'm going down the highway...
The rubber well-nuts are available from a variety of sources, and very inexpensively. Same for the plastic washers. The MV screws are kind of tricky to find though.
I'm sure someone will have a dash cover for you. Popular upgrade.
I have a 1090 cover listed.. I dont know if it will fit your bike
