1 - 15 of 15 Posts
I've been writing some of these writeups in my blog. Check them out if you're interested. They've got pics and instructions:
Squeaky windscreen fix
I lost the article I wrote on the clear lenses. Here are pics of it and a brief description though - you get the idea of what to do from these:
The flasher assembly to replace:
http://farm1.static.flickr.com/44/150049828_46a7329983_b.jpg
Closeup of the flasher to replace:
http://farm1.static.flickr.com/49/150050285_56e12690f3_b.jpg
Flasher back where it belongs:
http://farm1.static.flickr.com/50/150050661_59a6337ca7_b.jpg
Closeup of the connection that holds the silver side panel on the bike (so you can see how you are supposed to take it off):
http://farm1.static.flickr.com/52/150050924_77c5f31125_b.jpg
Closeup of the back of the same side panel (so you can see how you are supposed to take it off):
http://farm1.static.flickr.com/54/150051216_052e06e547_b.jpg
Stock wiring in the tail:
http://farm1.static.flickr.com/47/150052193_2fb360e261_b.jpg
After removing the stock brake light assembly:
http://farm1.static.flickr.com/51/150052587_e18f7fbdce_b.jpg
Comparison of the old assembly to the new:
http://farm1.static.flickr.com/48/150053110_87477e7be2_b.jpg
Here is where I got tricky:
I didn't want to cut the stock blinker wires. Instead, I opened up the blinkers themselves. This is what they look like inside. Note the quick-disconnect connectors used. This is the stock setup:
http://farm1.static.flickr.com/46/150053556_e2ff5f2723_b.jpg
Once you pull those tab connectors off, you end up with stock cables that look like this:
http://farm1.static.flickr.com/45/150054099_cc002044ab_b.jpg
I got the matching connectors at radio shack, and crimped them onto the new brakelight assembly. Then I could just plug the stock wiring into the new connectors on the new brakelight assembly. I then wrapped those connections in electric tape:
http://farm1.static.flickr.com/48/150054194_846abf2cef_b.jpg
I then wrapped all of the wires in red flexi-tubing for a clean look:
http://farm1.static.flickr.com/49/150054389_a032878e01_b.jpg
Zip tied it in place (racing yellow!) to stop it from rubbing or wandering:
http://farm1.static.flickr.com/56/150054508_b01e3c12c8_b.jpg
All done!
http://flickr.com/photos/thecodepoet/150054807/in/set-72057594127551547/
If any of that didn't make sense, let me know and I'll elaborate. the nice thing about the way I did it is that I didn't cut any stock wiring so I can always undo it, and it looks really clean under there.
Take care,
Ryan
I know what you mean regarding the squeaky screen, :bawling: it can be very annoying. :argue: The trouble I found was the wind noise through the gap like a partially closed door in a draught. :eek: I sorted it by using some draught excluder around the headlamp to seal the gap, this cured the squeak at the same time. :)
very nice "how to do it".
Remmember at the end to: take a sleep, wake up, check your work!
The guy MUST be drunk when he finishes!!! lolol
Sure, go ahead. You can copy the entries, or just link to them, though I would prefer the link.
The pictures are hosted on my flickr account, so you can just use those URLs.
Anybody try to use the stock red "glass" on the LED housing, so it looks "stock"?
I want integrated blinkers, but don't want a clear lense. I'm also not feeling putting LEDs into my rear vents.
Tried something similar, unfortunately it didn't work well with the stock red glass as the LEDs on the aftermarker unit light up red, and red on red glass doesn't show very well.
If you have LEDs that light up white it should work well.
P.s nice writeup.
P.s nice writeup.
I asked them to supply me one unassembled but they weren't interested :(
I was not able to open up this sight. Does anyone have the pictures and instructions on how to install the clear alternatives brake/blinker intergrator on a 2007 1000R?
I fixed the one link, but found that I'd lost the original tail light writeup. I edited the first post and added in the pics I still have and gave some basic descriptions. Hope that helps.
Anyone know if there's a bike store around melbourne (AUS) that stocks these? or stuck with buying them off the inter-webs?
1 - 15 of 15 Posts
