Can anyone tell me if its necessary to remove a fuse or the battery when the F4 is in long term winter storage?
If so which fuse should I remove so I don't get a rude shock when its time to awaken the F4?
Thanks.
Yes, check the maintenance manual, but your battery will still discharge over time and require a re-charge, especially if the temperature drops below 3 - 4 degrees in your garage.
How long will the battery hold charge before it goes completely flat.
My MV is a personal play thing, so she'll be in storage most of the time.
