I have no idea but I am intrigued. I think the R wheels are great and would love a set.
I would say the rear would be the same, but the front has a different axle mount, so if axle diameter is the same then it should be fine.
You would have to make sure brake discs are the same diameter and thickness or these would have to be changed.
The wheel bearings have the same part number between, "S" "R" and Tamburini, the "R" wheel has two aluminium inserts in the bearings to presumably allow them to use the same wheel design with the new forks or the ohlins on the Tamburini.
Brake discs on the R are 10mm larger, but I strongly suspect the mounting points will be the same :)
