1 - 12 of 12 Posts
My Brutale 750 - '05, has a problem that indicates an error in the SPU.
There is no power to spark plugs and fuel pump, while the lights, blinkers and starter normally operate, the voltage on the fuse "INJECTOR FUEL PUMP - INJECTOR COIL" varies between 6-10V at each new turn ignition switch to "ON" and then after 3 seconds falling to 0V unless is connected to the fuel pump, then shows a voltage of 0.1V when switch to "ON" and then drops to 0V. All contacts are inspected and cleaned, damage to the wires have not noticed.
Did I miss anything????
I searched the forum and found links which mainly refer to the "Vesuvio"
(www.oem-vesuvio.com, www.vesuvioracing.com) but it seems that these links are invalid. Is the "Vesuvio Racing" still in business? I see that a member "khameron" which is somehow connected with the company are not logged since 05-23-2011?
The question is how to get in touch with the "Vesuvio Racing" or some other reliable supplier "SPU" device?
Contact any authorized MV dealer....or better yet, one of the site sponsors:
MV Agusta of Houston TX
Pro Italia California
Trooper Lu in Australia
Or try CAG for possibility of a used one.
Hey Miko - Eddy's spot on...unfortunately we lost Vesuvio somewhere back last year :(
...don't forget to look at the back of the fuse cover (it has the OEM part# for the SPU)
I already have (only one in Croatia) still waiting for an answer when and at what price he can obtain the SPU.
Too bad for Vesuvio :(
I did not really understand what you mean with "Eddy's"? Who is Eddy :confused:
Eddy is Mr. Ed Eskew, a true gentleman of leasure.:naughty: Also known as Esq'z me, the mastermind in Brutale knowledge
Mea culpa, mea maxima culpa ;)
Still waiting for any info from my local authorized service.
Donsy, you give me too much credit...I just learned where to find info and happy to pass it along. Always learning.
Do like the thought of being a "Gentleman of Leisure"...too bad I have to work so much that there is little leisure time.
Reactions: Lawler574
Thank you all for your help.
By the Italian ebay I bought today a new type of "SPU" for 430 USD I hope fast delivery because Italy is a neighboring country.
In the meantime, I could not let sunny days go by without driving, so I bridged the wires, installed a universal automotive relay and brrrrrrmmmmm;-))
Actually something like this is not a bad solution because all the parts you need can be found at any auto parts store, very good when you're several hundred miles from home.
Here's a story in pictures
My "evil" box, and the fuse that gets electricity from faulty relay
Everything you need
On the large connector is necessary to remove the wire that activates relay
Blue / Green (+) and Yellow / Red (-)
On the small connector is desirable (but not required) to remove the wires that have voltage when the relay is activated
3x Red / Green wire
Temporary relay is mounted and MV Agusta could move on.
This interim solution can be applied to any other fault relays in the "SPU".
Of course, do not try something like this if you're not entirely sure what you are doing :naughty:
Small update.
New SPU (9615-V2) arrived, installed and everything works great. Indeed it seems to me that the engine works better and smoother, especially cold at the minimum throttle position (at the same time I installed a new iridium spark plugs and maybe because of it), switcing Hi/Lo beam is also somewhat smoother, generally I am satisfied.
Purchased on eBay Italian, vendors' alexthenext "
http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=260814161810&ssPageName=ADME:X:RTQ:IT:1123
1 - 12 of 12 Posts
