1 - 11 of 11 Posts
Wheel spacer on 1000R or 312R
Hello, could anyone with a 1000R, 312R, or any other bike that uses spacers on the front wheels have a quick check and tell me if this space is normal? It's on the right side of the wheel (sitting on bike). Thanks much.
My 312R is in deep slumber...if I can get to it, I will have a look.
I'd appreciate it if it isn't too much work, but do you really need an excuse to see your 312R? :)
Art;
it's normal, to double check loosen the right side pinch bolts and check the torque on the axle then tighten the pinch bolts
:drummer:
Thanks Noel. I swapped the original 312R wheels/axle with my Marvics and it didn't look right. I usually take pictures before I start doing things but this time I didn't. I actually put them back on twice to make sure I didn't do anything wrong. Just wanted to make sure before endoing the bike. The pavement is cold this time of year...
Joe, that axle looks like it has an awful off-set bend in the middle!:smoking::jsm:
1 - 11 of 11 Posts
