Anyone know what this connection is for on my B4 750? It's spliced in to the loom
@Manfred - there are three wires there. The charging connector only has two.If you measure the same voltage on the 2 pins like the battery voltage, then it is the charging connector![]()
Confirmation - From my 2003 B4 750 - Diagnostica Plug:It is in the correct location for the Diagnostic Connector. It has three wires - like the Diagnostic Connector.
The Wire Colors should be: Terminal 1 - Pink with a Black Stripe, Terminal 2 - Green with a White stripe, Terminal 3 - Pink with a Yellow Stripe.
