1 - 15 of 15 Posts
Hi Guys
Can anyone tell me what temperature does your fan kick in at?
I have heard the fan come in on mine a while ago but the temp gauge has started flashing once recently on me so i think its saying "help im too hot"
If the fan isnt working, what might cause it?
I have a 2003 750.
Its got upto 112 degrees c and thats when it started flashing and i paniced
ok so at 217f thats 102c so that means at 112c my fan should be on.
Any ideas what might be stopping it coming on?
Help is grately appreciated!
On my '00 750 the fan cuts in at 95C and goes off again at 89C. It starts flashing at 115C I think, but I've only ever seen it get that hot once, when I bought it and it hadn't had an oil or coolant change in six years. It's *very* rare I see it go over 100C. (And mine's a single-radiator 750.)
Si
It is due its first service so that may be it as it has been stood a while.
Its running ok on the open road but in town it starts to get all hot and bothered
The SPR turns on at 92C/198F and turns off at 87C/189F. I would suspect the other F4 750's are similar but don't know.
These bikes definitely are not traffic bikes, unless you want to toast your buns. I ordered and just received a sheet of adhesive backed reflective material to afix above the exhaust to shield the heat from toasting my back side while I'm waiting to get the hell out of traffic. Damn near had roasted chestnuts last week waiting for a wreck to clear. Would have hated to pull over and have someone think my SPR was on the fritz.
Lucky13 said:
Which model F4 do you have ?
Its a 2003 ev03 750 with just 400 miles on the clock. It has been stood for some time and did suffer from the slight coolant leak but i topped it up recently and it seems to have stopped leaking now.
I dont think that would effect the operation of the fan though would it?
Yes mate I know what you mean about that warm toasty feeling but ive been too busy enjoying myself to worry about that till it started to flash at me then i started worrying about the fan and how hot my ass was getting :eek:)
So it sounds like my fans not coming on. Anyone know what to check?
MV_Owner said:
Hi Guys
94C open in 312r
No it's most likely not related to your recent coolant spilage. In fact both conditions are unfortunately very common on the F4. Have your dealer check the fan operation thermal sensor and associating relays, but ultimately expect more of the same when in traffic with the F4. Sorry. I know it sucks.
1 - 15 of 15 Posts
