1 - 3 of 3 Posts
hi guys, what size brake fluid reservoir should i order from yoyodine? i got a brembo 19x18 brake master and i need a reservoir to go with it, im just unsure about the size. 30cc or 45cc? anyone who has this on their bikes please post pics of how u mounted the reservoir, thanx
I've got the 30cc reservoir coming.
As for the mounting, the most common method I'm aware of is to drill and tap a small hole in the top triple clamp, then attach a hanger and put the reservoir on that.
The next method is to use the top triple clamp pinch bolt. That approach takes a bit more effort to fabricate the hanger since it needs to still pass the pinch bolt through it. IIRC, the FBF AMA Superbikes use the pinch bolt approach. They made a small collar, which the bolt passes through, then welded a small hanger to that.
Alex
1 - 3 of 3 Posts
