Head bolts Frame Mount different
Ok ready to do the big swap today , but noticed something . The bolts that go through the frame into the head on the black bike are just direct bolts like on the rear of the frame, but on the red bike it seems to be a 2 piece pin type system.:stickpoke
are u referring to MY 2010 bike as compared to 2009 and previous ? Are you fitting a MY10 engine into an earlier bikes rolling chassis ?
joe
Ok, asked a lil in another thread BUT.
Wanna try to fire up this old 750 ( 2004 ) The main box on tank is missing but looking for a replacement and I have no gauge cluster
( which I was told I need to start the bike ) ,,DO I need the cluster ?
Also I see clusters marked 05-09 ,,what is the year breakdown on these things ? and why ?
also if I have just those missing parts should I be able to start the motor ?
Model breakdown ? I've posted the link to the model breakdown for you in your other thread, click on it and you'll be much the wiser. 99-09 use the same dash, 99-06 use the same ECU.
I know I've run my 1000 with the later 5SM ECU without a dash, without problems, so not sure if the 750 with the older 1.6SM ECU would run without a dash, only one way to find out.
Hope this helps.
Hope this helps.
Very much so thank you
