1 - 3 of 3 Posts
Hey guys - Just picked up my first Brutale and realized that I do not have the proper hex to get this oil pan drain bolt off. If I'm measuring right it appears to be an 11mm or 7/16 hex tip I need. Which one is it?
Welcome aboard. Metric fastenings on this machine. Get your self a set of Metric Allen keys, you will need them. I think it is 10mm btw.
If you are doing a general check, make sure the hub pinch bolts and chain tension are set correctly. Workshop manuals are available on the forum from Donsy.
1 - 3 of 3 Posts
