1 - 6 of 6 Posts
Donsy ,noel, any one what carbys will fit the 1078 brutale ,is the f4 1000 r the same .I know the 750 will not work.
cheers eddy
We don't use carbies Eddy, they're called throttle bodies man, don't confuse my little brain.
To tell the truth Eddy, I'm not sure, I know the F4 1078 has bigger TB's, Í can't say for sure about he B4. I'll do a bit of scratching around for you.
Where's that HB when you need him.
all 5 sets of TBs i have, measure 43mm ID on the manifold side
750s use Weber IWP-048 injectors.....they have a red band
910s use Weber IWP-156 injectors.....they have a black band
1000s use Weber IWP-162 injectors.....they have a white band
as flowed, IWP-162 injectors flow 35.5% more than IWP-156 injectors
the IWP-162 injectors are capable of producing 209HP @ 80%
http://www.rceng.com/technical.aspx
it is my understanding that the 1078s TBs were larger, but only on the inlet side....i have never seen a set
the only differences i have seen are the injectors as listed above and TPS sensors, a 1.6M ECU uses a different TPS than a 5 SM ECU
1 - 6 of 6 Posts
