1 - 11 of 11 Posts
It means the IMU is either not communicating with the ECU over the CAN bus or is providing unexpected results.
It can be a fault in the IMU, or it may have become detached from its mount.
If the lean angle sensor is unplugged, you will also get this fault code. Not sure about where yours is located but on my 2015 it is located under the left radiator guard.
Had the same fault, a faulty sensor can kill your engine which can bring you into troubles. talk to your dealer, either change it if available to get it removed...
cheers
mjvduc
I turned on my 2018 Dragster RR this morning and found this error code on the dash.
Fault: Lean Angle
Anybody knows what is going on?
I has similar error on my 18 Dragster. I took it to dealer and they checked sensor it was fine they ended up reseting ABS from MV diagnostic tool to clear it for me.
1 - 11 of 11 Posts
