1 - 3 of 3 Posts
Ok, I got a set from Motovation, says they fit F4 and 910. Well they might, but they sure as hell don't fit a 1078. So what does? Have gloss black Rizoma parts all over so want them to match and have enough weight to calm the vibe affect. Please let me know.
Had the same issue with a set of R&G ones. The well nut does not go far enough into the bars if memory serves me right to grip. If you offer your motivation ends up to the oem ones from the bike you will see what I mean (I hope!)
I managed to get around this by using a spacer between the inside of the bar end weight and the well nut. I think I had to use the oem bolt though.
Hope this helps somehow. Offering up the two side by side should help understand what needs to be done.
Dave
Nevermind, I'm retarded, that was the only problem. :)
1 - 3 of 3 Posts
