1 - 6 of 6 Posts
Quick question, can the water pump be pulled to change oil seal without draining the system and pulling the hoses, sorry if this has been asked before.
Year and model would help but I am certain you can do it with an F4. Tilt the bike back so you get minimal drainage from the pump itself. I would imagine it is the same with all 4 cylinder models but others with experience on those might say otherwise.
Just drain the system...... probably not new coolant anyway....
then you can work on a front or rear stand.....
vs being able to drop the bike to save coolant
:wink2:
Sound advice , is there a special tool to take off and replace the hose clips and can they be reused?
Bike is 2010reg Brutale 989r in the best colour of course Red!
The tool is Clic-R-pliers
1 - 6 of 6 Posts
