1 - 9 of 9 Posts
Hello,
as I have mentioned in my earlier posts, I have had a few problems with my f4 1000R.
It went to its 6000km service 3-4 weeks ago and since then it has over heated by that I mean went up to 116 degrees.
Today when I was driving to work the oil light went on after 10 kilometers and the engine temperature was at 100 degrees.
I cold the engine at a gas station then drove 2 kilometers to work.
I called the service place and they told me to come today over there. When I arrived after my work over there they controlled my bike and everything was normal. Just when I was leaving I wanted to show them that the temperature goes high, so that they can see what can be done with it.
The service guy started the engine and at 100 degrees some leaking appeared and a few seconds later a huge amount of cooling liquid came from the bike. After we took all the body panels off we finally saw that it wasn't leaking from the overheating leaking pipe but from a bolt of the water pump.
Now the water pump is going to be repaired.
What do you think has to be done? Do they have to change the whole pump or just the plastic joints?
Has someone had the same kind of problem?
advice me and make me more intelligent :)
cheers
martosh
Martti;
at no time should a water pump bolt be leaking especially just after a service....
if the seal in the pump is bad. the leak is from behind the pump
did you have the HO water pump installed?
Hitcho73 did....
they didn't do it correctly and his bike overheated too
Noel-theknurl
Had the same problem with the 1078 i.e. coolant dripping from the bottom screw of the pump.
Do a search on my threads and you will find pictures as well.
Summary:
Inside the pump there is a 'rod' which I had to replace together with some washers. Easy fix, cheap parts from Vesuvio and problem gone now. Dont overfill the tank after replace, stay below the MIN level (my bike standing straight when cool, you can hardly see the liquid surface at the side-its low) and you ll be fine. Maybe its sth else with your bike this is my experience.
Rgds
Phil
Hi,
I have everything OEM on it.
It just over heated after the service and now broke down.
They will replace it cos' on guarranty.
Martti;
Hitcho73 did....
Noel-theknurl
Tx for the thread.
We will see what is the problem with it after the service guy will have it taken appart.
We will see what we have to do, the importer in Finland has never had that kind of problem before.
I might later change it to a bigger pump but I will let the fix it before, when it will work I will eventualy change it.
It's now warm in here 88 degrees fahrenheit in the shadow. And when you are stuck in traffic it just overheats. Will see how it works after the new pump. But tx all for the responses
Hi there,
my bike is still at the shop, they tried to change the joints in the pump but it doesn't help. Now they are waiting for a new water pump. At the same time they can check the engine and the covers because the oil light went on...
What else would you check on the bike at that same time? What else might be broken on it, if the oil lamp went on. The pump is going to be a new one but are there other possibilities of parts that you would check.
I am still a newbie on it and I don't want to be screwed by the guys in the shop. Everything has to be check now on it.
Give me some info and I will ask them if they have check those parts.
cheers.
martosh mv for ever
I would get the shop manuals for your bike and learn how to do all this simple stuff yourself. Alot of it is just common sense, patience and the intestinal fortitude to pick up a wrench and lay it to the bike.
1 - 9 of 9 Posts
