1 - 20 of 57 Posts
Hi.... its me again with another problem. :(
My bikes oil seems to be emulsified and its very milky. The oil... is 3 months old. i use it to go to work and back 5 times a day.. its a 2 mile trip each way.
i read somewhere that it might just be condensation.... but it seems a lot of white milky oil is present... and surely it cannot be just condensation... but a rather more serious problem of a possible coolant leaking into the oil sump?
what do i do here? water pump gasket? head gasket?
any help would be amazing.
Cheers.
Ersan.
Well it looks like you got your tank off already and opened the air box so might as well do a compression check.
i would need to find a compression tester for that, not sure what they cost but ill do some research.
cheers!
Well, first of all, how does the coolant level look? And the coolant itself. Oil in it?
Condensate to this level does not happen overnight. How long since the bike had its oil changed, ridden and when you noticed this condition - ie the time delta? What are the storage conditions? Ambient or outdoor storage creates condensation havoc with machines that sit.
Yes, you may have blown the head gasket but there are 20 things to check before you do a leak down/compression check. How do the plugs look? Is there water in the cylinders? Are there visible signs of coolant around the head gasket or headers? Anything coming out the pipes? Or in the pipes?
Further to what Rob mentioned above, the oil and water pump run on the same shaft on the 3 cylinder bikes and it is located in the oil sump so any leak of coolant at the pump will drain into the oil.
I would first check the compression as mentioned by Rob above to check for leaks on the head gasket. If all is okay with the head, then it could be an issue with the pump seals, drop the oil pan and inspect the pump seals for any water leaks.
Yes to all above.
And one more thing. DO NOT turn the engine over until you have removed the plugs. If you have enough water in the cyls, you may damage the rest of the engine since water is not compressible.
The oil is only 3 months old and so are the plugs. the bike sits outside my house not in a garage. and i live in Scotland. it gets pretty cold here and pretty rainy. when i park my bike after riding, there are small puddles of rainbow coloured liquid thats comcing out of the small pipes under the bike. i dont ever see them driping in person. but next day there is a small puddle. like 15 drops worth of a puddle size of rainbow coloured liquid.
i will try everything you guys have mentioned! and i highly appreciate it. i just need some time.. its such a bad time for me these days!
You don't say if you have checked the coolant level and if any has "disappeared". If it is as it should be then you likely don't have a head gasket or waterpump problem.
The conditions the bike is being kept in wont help and the very short run nature of its use could lead to mayonnaise (condensation) forming in the engine. The oil will scarcely be warm after only two miles in winter weather. I don't think the oil cooler circuit has a thermostat.
The puddles you are seeing under the bike sound like water getting in around the fuel cap and finding its way in the well under the fuel cap and down the drain hoses to the ground taking a little spilt fuel residue with it.
If the oil is obviously cloudy it needs to be changed and any mayonnaise you can get to cleaned out, and then ride the thing as its makers intended!
I you do have to make short runs in winter try covering the oil cooler, that should help keep some heat in the engine. That CNC clutch cover is very trick but it should be double glazed.
Water is a significant by product of combustion - like 1:1 for a gallon of gas - so it is not unusual to see water in a tail pipe or as vapor coming out of same on a cold day. Nevertheless, @esq'z me has already advised that the water pump is an issue with these bikes so that is maybe the second or third thing to check - right after the coolant level and quality. But the storage conditions are just about the worst they could possibly be in this case and condensate could also be the issue.
I can also assure you that this kind of storage will cause further, perhaps unrelated issues and will ultimately be the demise of this motorcycle.
My two cents:
(This is another case, as are all cases, where it would be beneficial to have the bike model and year. Is this a 675 or an 800? Please add that to your signature line.)
1. Yes, the oil is emulsified and should be replaced. When you drain it, drain it to a container and let it sit to separate. You will be able to see how little water it takes to emulsify oil.
2. Your storage condition is unlikely to be the cause of this. Conversely, if you are one of those folks who likes to start a bike for very short periods of time "just to get things moving", then that can be a cause. IF you are going to start an engine, you need to ensure that the system is brought up to temperature and held there long enough to bring all fluid up to operating temperature and drive any condensation out. That takes time and is best done on a ride and not just sitting. There is also no good reason to do this while a bike is in storage.
3. Covering your oil cooler will do nothing to help. This is not a situation where you bike is running at a low temperature.
4. Ed's suggestion to check the water pump is a valid one. As stated, the pump lives in the oil sump. A small leak there will cause a big issue in a short time.
5. Look for the small easy fixes before tearing the top end of your engine apart.
Below is the parts diagram for the 675/800 triples oil and cooling system. Note the circles item is the water pump portion of the combined oil/water pump. There are many o-rings and seals that can leaks causing your condition. It is a "relatively" easy job to drop the oil pan and check the conditions.
Further to all this...head gasket leaks tend to push combustion gasses into the cooling system resulting in overheating, and if bad enough to let water into the engine will result in clouds of white smoke from the exhaust.
Riding a bike for 2 miles at a time never allows the oil to warm enough to evaporate moisture.
Should you find the coolant level is still normal and stays that way then you know your problem is just condensate. Check the coolant level...OK?? Go for a long ride.
If coolant level is low and dropping then go for the water/oil pump....much more likely source of problems then the head gasket.
Jeez, You folks make this complicated
Pressure test the cooling system.....test it at 0.1-0.2 bar over the cap rating
If it leaks down, but you don't see any external leaks?
It's internal:grin2:
Take some coolant to a mechanic that works on cars or trucks, they'll have a chemical to add
to the coolant that will show if combustion gasses are present.......No Gasses?
It's not the head gasket
It's the water pump seals:wink2:
Lots of good suggestions here. You can also check the oil pan where the 17/18 part call outs run to. If your pump is going bad or rings deteriorating you will have drainage from the oil pan where that tube runs.
Sent from my HTC U11 using Tapatalk
Discussion Starter #16
So much help! thanks so much everyone. I will be starting work on the bike soon after xmas, i will start with the basics such as coolant level and condition etc. and work my way down.
Discussion Starter #17
Update guys,
so its only now i have managed to start work on the bike as Mv Agusta apparently had delays at their wearhouse on ordering parts...still havent gotten anything yet my parts should arrive next week... but i decided to remove the plugs....and ive ran into a bit of a problem, 2 out of 3 plugs came out no problem, and yes they were drenched in oil. The last plug.... wont come out, or rather.. the socket wont catch it... there seems to be a black bit of plastic around the plug.. i dont know where this came from, as the plugs are pretty much brand new, i replaced them only 4 months ago.
here are pictures of each of the plug holes. and you can see the difference on the 3rd one.
Any help would be appreciated!
thank you
Looks like the rubber tip on the end of the coil has broken off and is sitting on the plug.
Just use a hooked seal pick and pull it out.
Discussion Starter #19
got it out, but it wasnt the coil end. it was weird rubber...but not sure where its from.. defo not from the coil as the coils ends looking normal as the rest of them. im thinking it would possibly be the inner rubber of a spark plug tool. how have i not noticed this when installing it, god knows. but its out now. i wonder if that hindered the bikes performance.
Some tool left it in their then.:wink2:
Hope I am not referring to you.lol
1 - 20 of 57 Posts
