1 - 15 of 15 Posts
as it turns out locking the passenger seat latch by smacking my fist on the seat has its downside.....
it bends the bracket on the bottom of the seat......and the latch SEEMS locked.....
a bump in the road will unlatch it.....:wtf::wtf::wtf:
ask me how I know.....:ahhh:
happened this afternoon, got to the gas station, no rear seat, hasn't been off for 2 days
so if the latch is getting hard to work......check the bracket for bending
I went back and found it .....perfect excuse to get new seat covers:wtf:
I have a habit of hitting mine back into place, but having heard tales of others flying off I always also try and pull it back off again, apart from once when you can guess what happened....
The latch bit does apppear to be relatively flimsy with no design to allow the pin to slide it out of the way other than the pins taper. I'd imagine after smacking it in a number of times it would eventually chafe the pin enough for it to start catching on the latch?
Are you going to repair the existing one Noel or just go for a new latch? It would be interesting to see if there was a better way to setup the latch system to better guide the pin in.
I close mine gently and as suggested above, always check to make sure it's clicked in to place. Be nice to your Bruite, she brings you too much pleasure to pick on her.
I close mine this way:
1. Put the seat on so that it is resting on the lock.
2. Turn the key enough that the seat slips down partly into the lock.
3. Firmly press down on the seat until I hear a "click".
Works like a charm, and no violent motions involved - plus when I hear the little "click" I know it is in.
Discussion Starter · #6 · (Edited)
the fix;
relieve the back side of the notch in the pin, on the upper side.....
look at a hood latch on a car
seat latch was a bad design......overweight pillion would bend it too
I bought it used and it wouldn't latch unless I gave it a little smack at 4,000mi
I check it every time I get on the bike, and some times at traffic lights too
now I need one of Ade's masterpieces :drummer::drummer:
i put a piece of Stainless cable on my seat so if it comes off i dont loose it ..like i did the first time
Discussion Starter · #9 ·
Col;
Lee sent me the smallest stainless cable he had.....still too big and not coated....
and I even have the nicopress to crimp the cable
car hoods don't fly off :drummer:
so now time to upgrade the seat covers
:popcorn:
Ade......you listening?
Ah yes.....long ongoing history of missing Brutale seats if you search back in the forum.
I now just make it a habit to tug firmly on the back edge of the pillion after reinstalling. If it isn't latched fully it will pop right up.
Many thousands of miles after my "missing" pillion seat incident. No problems. Of course, it also can't fall off with Pillion Pam on board!
overweight pillion
the fix;
or maybe it was a perfect design?
A friend of mine had a sticker back there that said "no fat chicks"
Discussion Starter · #13 · (Edited)
bad design June......the latch takes the weight of the lard ass, because the locking bolt isn't relieved on the backside so the bracket is taking all the weight
I don't need a "No Fat Chicks" sticker.......
I don't know any:naughty::naughty::naughty:
my Polish friend;
https://scontent-a-lax.xx.fbcdn.net/hphotos-prn1/t1.0-9/1521978_419965398136648_2013110548_n.jpg
https://scontent-b-lax.xx.fbcdn.net/hphotos-frc3/t1.0-9/486040_283346101798579_633061371_n.jpg
https://scontent-b-lax.xx.fbcdn.net/hphotos-ash3/t1.0-9/73526_343291672470688_1276251667_n.jpg
and the Italian paratrooper;
https://scontent-b-lax.xx.fbcdn.net/hphotos-prn2/t1.0-9/1450951_554760124611574_527994521_n.jpg
https://scontent-b-lax.xx.fbcdn.net/hphotos-frc3/t1.0-9/1607006_586726811414905_2037636398_n.jpg
they won't bend seat latches.......
I've read a lot of threads and comments on this.., and honestly have never had any issues.
I simply just fit the seat pad in place and gently 'push down' in the centre of the pad until I hear the essential 'click'.......job done!
And in 'opening' the seat....,I gently push down on the centre of the seat pad whilst turning the key to slightly 'ease' the key turning .....no issues...no problems.
1 - 15 of 15 Posts
