Hello fellow MV Agusta owners,
With the happy ownership of a MV Agusta F4 1000 R 2007 comes the search for the standard fixes for known problems.
I am looking for:
- Metal Muzzy fan blades for F4 1000 R 2007
- 1/4 barb male cpc fuel connectors to mount on the Original hose
Please reply if you have any of these lying around.
Thanks in advance,
Peter.
Discussion Starter · #2 ·
Also wanted: original tool set for the bike. Seems the only part missing. TIA!
No luck so far...
Peter;
try Ebay there are a few tool kits on there, I just looked
:drummer:
I am looking for:
Thanks in advance,
Peter.
Peter,
One action that is important with your bike is to change out the rear most well nuts in the small black trim panel under the airbox for metal Riv nuts.
Do a forum search on riv nuts and you will see the problem. The oe well nuts have a metal ferrule in them which if the rubber fails on the well nut can drop straight into the air intakes and wreck your engine.
So this is an absolute must do, Metal riv nuts by dint of their design can't fall inwards.
There is apparently a problem with supply of the Muzzy fans..Maybe this delay has passed now ?
You can buy your 1/4 inch connectors from Colder Products or Quick connects in the USA...There is also a UK company called Parkers that sells the quick connects.
Your bracket will be with you next week :)
joe
