1 - 20 of 20 Posts
My 1078 gets a vibration through the bars at around the 5000rpm mark that will send my hands to sleep if sustained for a prolonged period (yes I know that is over the speed limit) ,anyone else get the buzzies or is it just my bike and anyone tried different weight bar ends. Thanks,
Cus.
Do a search on Bar end weights there are some heavier ones out there - Answer is don't hold on so tight :laughing:
try this setup,this will greatly reduce it,plus i have put on a matris m4 steering dampner,all this has reduced it,but not toally gone,
good luck
cheers eddy
I filled my bars with expanding foam which I bought from my local hardware store.
I've done this now on a few bikes and it seems to do the trick.
I have the same bike as you and eddypro and the same barends as eddypro. Get them, it doesn't just cut down the vibe, it eliminates it. They work.
I have a Scott damper set kinda stiff, and I wear gloves, maybe that's why I don't notice it at all. I think eddypro and I have almost identical mods done without knowing it. :)
yep, pretty close,have you had your bike tuned yet,not trying to change subject,just curious.
cheers eddy
Is scheduled, just got the race ecu in. By early March, the shop likes to do it when outside temp is closer to riding temp.
good luck
cheers eddy
eddy what ends are these cant read,and are the mirrors the arrow billit ones...looks good.Nice set up.
1 - 20 of 20 Posts
