1 - 17 of 17 Posts
My bike is due a service at 8500 miles I spoke to two dealers today and both gave different answers. One said they don't need checking and the other did can some one shed some light as there is a bit of a difference in the cost of the service. I need this as I want to keep the book stamped up. Thanks.
Manual says 12,000kms or 7,500mls so yes they are due to be checked.
Checking is not a big job, and they will likely all be in spec. Adjusting is when the big $$$ come in to play.
Mine have been in spec every time I checked. 4 times now.
Chris at x bikes did mine and the price was very reasonable, they take the frame from the engine so as to give plenty of clearance to get those cams out. I think you cant beat the experience chris and his crew have in dealing with this job as they are well practiced at it.
12,000 km valve check and plug change too. I'll need an air filter change as well. High maintenance baby.
wtf???????
you geniuses don't have a clue.......
you going to change the drive chain at 7,500mi because the manual says so??????
you're really going to get bent over at 22,400mi
timing chain, chain guides, chain tensioner, front wheel bearings, REAR HUB etc
and another set of plugs too :naughty::naughty:
my '08 Brutale 910R has 32,000mi
I never looked at the valves......
the chain was adjusted 20,000mi ago its in exactly the same spot......it never gets
lubed .....sprayed with WD-40 and wiped down that's it
the front pads EBC HH are ~50% worn......stock Brembo POS go 8,000mi on my Aprilia
RSVR
rears went 2,000mi ago
failures;
burned out 2 low beam bulbs
screw fell ot of the front brake light switch
battery lasted 8 years
best thing you can do for your MV?
reduce the pinch bolt torque to 15lbft/20Nm
I TESTED the torque values that distort the 3810-2RS bearing nobody else did, I
repeated each test 5 times
RSVR
failures;
What if the valves are out of spec.
Then it won't start.
My friend Felix da Cat on the Aprilia Forum at last report has 140,000 km. Valves still in
spec......and they're bigger, heavier valves......
I like Chuck's answer
:popcorn:
Dumb question?
Wouldn't pulling the plugs and doing a simple compression and leak down tests @ 7500 mi /12,000km tell you if the top end is ok? Seems less evasive than breaking the seal on the rocker cover and breaking out the feeler guages etc.
not sure what you can expect if the engine is cold. what if the exhaust is 0.006 and it should be 0.012? no leak but still out of spec. no question is stupid only the answer. how else can we learn? valid question!
Leak down test would only tell us part of the story, won't know if your losing valve lift.
So maybe thats my answer
Out of spec is one thing.
As the valve train wears the result is a valve that remains slightly open...or simply not tightly shut. That is when you will have hard starting issues. A good sign that it is time for an adjustment.
Chuck I agree . the example I used was actual clearances on an L twin engine I have from new which had always popping on de-acceleration in the exhaust. now no popping and smoother from idle to 4K rpm.
thinking about this you should be able to see this with vacuum gauges
1 - 17 of 17 Posts
