Hoping someone can help or put me in the right direction
Tracking am F3 800 and it turns out that although the bike on a whole is very good, it does have a few weaknesses
The slipper was one but an easy fix
The abundance to drop a valve due to weak springs not so
So has anyone had this or similar and if so what did you upgrade? I'm told there are stiffer springs from other makes that work on this engine
Is there anything else that can be recommended on one of these for track only not road. It is used at the very top end of fast group so it's constantly high up in the revs
I would contact passerini performance on facebook!
The tuff I have bought from them has been top notch, and will be doing their ecu reflash and race header this winter.
What was the issue with the slipper clutch exactly?
