I have a b3 800 2013 and sometimes the gear number display is off by 1 gear, or sometimes it keeps twitching between two numbers.
Is this a known problem? I still got warranty.
It is, check out the search function on the forum and you'll find all the info you need.
Multiple threads about this issue.
Good luck !
Let your dealer know, they should order in the new revised gear sensor that MV have and fit, had mine done last November all under warranty :)
Simple warranty fix.
Call your dealer and make sure the have the part in stock. The replacement takes about 10 minutes, BUT you have to wait for the bike to cool off because the location is really close to the exhaust. So, it's 10 minutes of labor and at least an hour of wait time.
Since mine was replaced it has been rock solid and dead reliable.
