1 - 20 of 27 Posts
Hi everyone,
Since few weeks, I got a warning message on the dashboard times to times with "Fuel level sensor failure", and the loss of information regarding the level of fuel in the tank on the dashboard. I'm not too worried about it as I do use the mileage indicator in the meantime, and it is still at this stage a non permanent issue. I found out that the sensor (8000B9950) cost about 200€ TTC, but before doing any change considering any possible ways to repair it. My first attempt was to contact spray the plug, with no (expected) success.
I did then more search on this. It is a thermistor, and the corps of the part is heated (found some information on those type of sensor here). I suspect the fact that the part is heating may suggest an issue with the soldering of the wires on the thermistor. That would explain why it works sometime and not some other times (liaison getting loose with the temperature, then contact is not good enough)… Will have to unmount and try to solder it again.
Any other ideas?
Eeny, meeny, miny, moe
Either your sight is on par with the sight of an elderly grandma mole
or your memorizing worth the smarts of a goldfish.
Or your TV is different.
Right after the 15 000 km service my fuel level sensor broke down.
For good.
And has been on the blink, truly on the blink, since.
I wasn't going back to the shop for such trivial annoyance.
Month of april passed
by phone the story rang:
"you have to bring the bike we need the error-code to process a warranty claim"
"Not this week mind you, call the week after"
From the week after to the next week after came May.
"Can't do anything on your bike! Our mechanic is on vacation, you know this month, lots of vacations yadayadayada"
"Oki docky. Allright now. Mechanic is back, but all the other serfs are gone in vacation.
the poor guy is overworked."
Call next week or better, the week after.
-"We have the error code says: 'fuel level sensor error'"
Pfiuw
Fired an email to MV who immediatly fired back they had no claim pending for no fuel sensor warranty...
Back on the horn
-"Right! The TV lusso has a fuel level sensor, not your Veloss Vulgaris, MV covered it with masking tape!"
-"MV hasn't got no warranty logged"
-"Doesn't surprise me. Internets broke down while we was trying to write an email for warranty"
-"Lets try next week or better call us the week after next."
Up to this WE it was mildly irritating, bordering on real fun.
Then one of our sinisters announced on TV (the thing with a big, big flat screen) about some strike:
"there won't be no gas shortages no rationing of gas..."
Was about to ride for a short day hop about 780 miles to see the ydrovolante at Biscarosse
The minister, or was it an under-secretary, was still droning on TV (the flat screen one)
Watched very long lines form at the service station and decided, in solidarity with the strikers
whoever they are; no leisure jaunt today.
Monday the service stations around here were closed,
Dry.
Only dry places around here.
They ddn't even have time to do some rationing.
Having no reserve light, no fuel level
and no way to find gas around got old very fast.
Tomorow I burn the last fumes of my gas and drop the Turislow Vulgaris at the dealer.
Fun ... the trains are ALSO on strike
And even if they wasn't, the Savenay train station is closed, flooded.
when a fuel sensor isn't a fuel sensor
... MV end up replacing the fuel sensor under warranty. no more issues.
And missed all the high italian drama.
The machavellian combinazione.
The smooth shift in less than two sentences from blatant untruth to baldfaced lie!
This morning catch; before I putputted back sedately on a loaner Lusso:
-"We got the part. But it doesn't say 'fuel sensor' might not be right"
>:) è un aumento di suspense
inglese: "You bet"
It doesn’t say Fuel Sensor because the sensor is part of the Wiring Harness for the fuel pump. They will be replacing the wiring harness and that contains the sensor.
Italian flair
It doesn’t say Fuel Sensor because the sensor is part of the Wiring Harness for the fuel pump....
It's a TV!
The TV tank like the Stradale tank has a very long fuel level PROBE on the RH side of the tank with his own wiring independent from the fuel pump harness.
Both fuel pump and fuel probe connectors are next to each other left and right on the front side of the battery.
They have different terminals and different colors.
The error msg says: fuel level sensor.
Rang the dealer just now.
-We have a valid warranty claim.
But at MV the part is not available so we have to wait until they list it as available.
So I guess, wait for the 30 000 km service, with no fuel level and no reserve light.
On the TV the yellow light is also wired on the fuel level probe, not on the fuel pump assembly.
The dealer noticed the non Lusso TV HAS a fuel level display.
-"your bike had some masking tape, the tape was there for a reason..."
We compared the dash on both bikes.
The guy noticed some difference.
"Right
you see, on the Lusso it shows the fuel level, it doesn't on your vanilla TV!
You sure it showed the fuel level once? 0:) Maybe 'twas just your imagination..."
"Right
I can confirm the non Lusso displays the fuel level :) (when the fuel sensor works).
Called my dealer, asked him to order one for me. He told me as well it is out of stock currently. Discussed with friends, all of them are quite surprised with the thermistor used for this purpose (except those riding GS 1200 Liquid cooled BMW where this is quite frequent issue as well, for the same reason). Two possibilities there :
  • sometime works, sometimes not (specially when hot) > wire soldering issue
  • permanently not functional: fuel level probe is dead
Now, the thing is the wire is soldered on the sensor, and there is some composite material formed on it, which seals it. Not sure if there is a way to repair it due to that.
Additional bits : issue seems more and more frequent here and there… MV seems to listen customers, so we may hope a part revision at some point, with something more reliable...
@Arcimboldo: Sorry about that, I was posting on my phone and didn't see the TV Reference.
Do you have the electronic TV and/or Stradale and/or Rivale workshop manuals?
They call it a fuel level probe or sonda livello carburante.
Looks like it's a float type device.
found this youtube video of a guy with one(not MV) out of the tank and apparently he was able to clean the contacts and make it work? (note: I don't know what he's saying.)
Also found a couple of sonda livello carburante on ebay, though they were for Ducati...
https://www.youtube.com/watch?v=w5fM8e2BQok
As per what my dealer told me, it's not a float type device, but a thermistor (same as some Ducati)… And you can find some on eBay for the TV:
- here, located in US
- here located in Italy
Man
[Canned laughters]This is no fuel level sensor.
No my good Sir.
This is a belgian blinker
...apparently he was able to clean the contacts and make it work? (note: I don't know what he's saying.)
[More canned laughters]Doesn't look like the fuel sensor probe on a TV, not at all.
And I know what I'am saying.
This moaning
just got a nice friendly email from MV Varese Customer Care
"Mv Agusta in this case advise you to replace the component instead than try to fix it"
Peepul that dick around
trying to fix some electrical malfunction, in the tank, mostly I avoid
like plague.
Yesterday, my dealer took off my tank and bolstered his case
He found that the fuel sensor error code
is the result of a fuel sensor malfunction.
Fuel sensor that MV Agusta hasn't got in stock presently.
Got all manuals, all the doodads for the TV, the Stradale including the last updated thumbdrive.
A beautiful steel, laser engraved object AND a pair of working stickers.
[More canned laughter]
Inside my tank, gas fumes and all that,
better a thermistor with poor contacts than a short.
Any chance that you would share those manuals with the greater MV community?
I'd like a personal copy sent to: [email protected]
If that isn't too much trouble.....:smile2:
Workshop manual:
Remember the Stradale is no RIVALE but a TV in Rivale cloth:
Follow donsy's link
Some differences betwen Stradale and TV:
The wiring diagram;
The Stradale came with a paper wiring diagram at the back of her User Manual.
Wasn't the diagram for my Stradale.
Handguards and the DRL on a Stradale are different from the TV.
Handguards on the Stradale have a 3 terminals connector, two terminals only on the TV.
Taillight, stoplight wiring and parts are the same on the Stradale and the Rivale.
Different connectors on the Stradale body and on the panniers.
Slipper clutch: no slipper clutch on the Stradale.
Now about the USB thumb drive:
Maybe the Stradale or TV won't show up on your front screen.
Navigate to usbkey09/bin/upload/pdf/catalogues/
probably all the pdf for user manual or "maintenance" manual Stradale and TV are here.
Posted the TV manuals a while ago.
Also posted the Stradale manuals next to the TV manuals but no one touched them ever.
Thanks. Working my way through the linkages now.....
Got 'em all. Thanks.
Thaks for this Arcimboldo.
Cheers!
Reviving an Old Tread.
The Fuel Sensor on my bike seems to have a mind of it's own. I get the sensor error message on start-up sometimes - sometimes not. Riding along, nothing particularly going on and it's starts to flash the error message and the fuel level goes to full and blinks on and off. Not sure if topping the tank off a little more than normal had anything to do with or not, but immediately with the fill up was the first error message.
Ordered a new sensor and the shipping is rather dear to the states. I wasn't sure if anyone figured out if these things are repairable? If so, I would appreciate a link to the thread.
BTW - Teeps - Thanks for the tip on de-soldering the Clutch Sensor switch. It did make the R&R job a lot simpler.
Discussion Starter #18
It's started this way on my side. Later on, was working only when weather is cold and stopped working when engine hot. And few weeks later didn't worked anymore. Replaced by a new and expensive part. I still have the broken part somewhere and I'm quite decided to dismantle it sometimes to understand…
If you ordered from StarTwins it certainly is...
You didn't order from a US dealer?? You do know they can get parts usually within a week to 10 days???
Reactions: Lorretto
You are welcome. Happy to help.
1 - 20 of 27 Posts
