Hi All,
I didnt know who else to turn to as im a bit concerned I could have done damage to my new Mv Agusta Brutale 800 (2015)
I have just changed the sprockets and chain however, as I was tightening up the front sprocket to 140nm with a hand torque wrench I didnt realise it was in gear which resulted in a momentary clockwise turn of the front sprocket (Oposite to the way the engine runs)
It sounded horrible and I stopped as soon as I realised what I had done. I think the sound was likley the starter motor as I understand the sprag is essentialy a one way clutch. Hower I am concerned I could have done other damge I am not aware of.
She starts fine and the starter motor works okay, but could I have:
- Upset the timing?
- Affected the cam chain tension permenantly
- Any other adverse effects that may not be immediately detectable.
- I would know if it had jumped a tooth right?
I guess what I am saying is should I be worried? and would it be obvious if I had done any damage !?!
I really apreciate the help in advance.
Dan
There is nothing that I can think of that you might have broken. It will be fine.
I have moved many a bike backwards with the gears engaged. No issues...ever.
Reactions: RedBrutale
I have turned many an engine over backwards, it would only become a problem if the cam chain tensioner was loose. No need to panic
You can't hurt it turning it backwards...... like the other guys said. No worries.
Dave your humor is always a welcome site on here.
