Hello guys recently bought a Turismo Veloce 800 and only couple of weeks on the road noticed that coolant temperature goes over the 5 bars .I know the basics and start checking the possible reasons for that - cooling fan does not work .Test the fan itself with 12V and does work perfectly ,replace the radiator temperature sensor ,replace the relay and kept experience the same problem .After test all the usual component that can fail I did replace the engine Ecu.With the new Ecu when the coolant reached 80° fan start working only for like 5 secs .That happened when run the bike first time with new Ecu and then fan never worked again .Can anyone help ?
How old is the bike? Should still be in warranty unless it's one of the early ones. I would be taking to your nearest MV dealer. Where about in the World are you located (useful to anyone responding and easy to add that to your profile).
My TVL does struggle to maintain temperature in certain circumstances (i.e. stuck in traffic) when the weather is hot but the fan always kicks in.
I am in Uk .Bike is o e year old and got 550 miles on the clock ,but because got a tracker ,aftermarket alarm and sat nav installed dealership has been funny about the warranty .When the fan is suppose to kick in 80° 90° 100° ?
Sorry can't recall temperature in and out points but around 105ºC sounds plausible with it cutting out once temperature drops to around 95ºC and cycle thereon depending on conditions and airflow. Under normal conditions and when in motion forced airflow through the rad should suffice and the fan not be required.
The workshop manual only says "The electric fan must start up when the water temperature reaches the 5th or 6th notch on the dashboard."
Sounds to me like you need to use a different dealer. I have all the electrical accessories you mention and have had no issues with warranty claims. If you're in the South then Motocorsa, near Shaftesbury, gets a big thumbs up from me.
