I need to know if there are any electronics in the ignition key , Please ?
I've just fitted my SW Motech tank ring to my bike, this is the quick release type and fits my Micro Tank Bag,
Not enough clearance on the key , only need to remove about 10 mm from the red plastic top,
any help would be appreciated, wanted to try it out tomorrow :jsm:
yes there is a little chip in... for the immobilizer!
just be carefully how much u will remove. I think the chip will be near the middle of the key. near the metal from the key...
I read that Gero, not saying I understood it all, lol, I'll give it a go ,and start it up tomorrow, if it doesn't start,I'll use the other key, It all get a little technical at my age I usually get the dealers to do it,
Remove the mounting plate from the bottom of the tank bag, measure how much clearance you need to clear the key, get 4 longer nuts and bolts and make up /buy some spacers to lift the bag away from its mounting plate enough to clear the key . Bolt it all back together.
glenn
Either that or send the SW Motech bag back for a refund and get a Givi one. Don't have clearance issues with the small one I use on my TV.
