i was looking at the F4 wiring diagram for the 2005 bike, and it had a system called TSS on it, which is only on the Tamburini at this point.
i didn't know what it was, untill now. it's a varible length intake system. it's not very sophisticated, but it's a first on a production motorcycle. btw, LOTS of cars use similar sytems.
here's a VERY good description by Kevin Cameron (MIT grad) of Cycle World. it's posted elsewhere on the net, so i've pasted it below. i've also included a link to the full review of the tamburini, which i belive is also on this forum.
alex
TSS, Intake tract trickery
Variable-length intakes such as the MV Tamburini's Torque Shift System make us think of Formula One or of the last of the racing Mercedes 300SLRs, but the concept is useful wherever engine torque must be maximized across a range of rpm.
First, some physics. When a piston drops on its intake stroke, a deep vacuum of about half an atmosphere is immediately created in the intake tract. This propagates from the piston crown toward the intake's open end—the bellmouth—at the local speed of sound (fast!). When it reaches the end, atmospheric pressure rushes in to fill that partial vacuum, creating a reflected pressure pulse that crashes back down the intake pipe as a wave toward the valves. If our wave returns to the cylinder just before the intake valves close, the pressure in that wave will be added to the pressure in the cylinder, making a denser charge that equals higher combustion pressure and increased torque.
Often there is not room on a motorcycle for intake pipes of the necessary length, so the designer will allow the intake wave to make two or more trips up and down a shorter intake pipe. Each reflection of the waves loses some of its intensity, but compromises are the engineer's stock in trade.
By using an intake pipe of ideal length for the desired rpm, a torque gain of the order of 10 percent may be achieved—but only across a limited rpm range. To have both a robust midrange (the Tamburini's peak torque on the CW dyno comes at 8700 rpm) and strong top end calls for having two different intake lengths. This is just what TSS delivers. The MV's four throttle bodies have short, permanent bellmouths suited to top-end power, but a set of moveable extension bellmouths is carried on a pair of linear bearings. Below 10,000 rpm, these extensions are in place, creating a longer intake tract that boosts torque. Above 10,000 revs, a Pierburg pneumatic actuator (run on engine vacuum) snaps the extensions up and out of the way, shortening the intake tract to boost breathing and thus power on the top end. This is a two-state system—it is not progressive—as the extensions are moved in or out of use within 0.15 of a second.
Because the change of intake length is carried out at an rpm between peak torque and peak power, where the engine's torque is less dependent upon intake length, torque at the "shift" point does not change greatly.
A similar two-state variable intake length system was used in Superbike racing by Honda on later RC45s, but this does not violate MV's claim that TSS is a first for a production motorcycle.
— Kevin Cameron
http://www.cycleworld.com/article.asp?print_page=y§ion_id=12&article_id=22&page_number=1
alex
— Kevin Cameron
