So I really like my Stradale but I feel the rake and trail causes sluggish turn in and more pressure on the bars to maintain a line than I like.
Has anyone raised the fork tubes in the triples, and if so, how much and what was the result?
I'm feeling like 5mm is a good starting point.
I thinks steering geometry is a very personal thing.
That being said, there are those on here with the Stradale that will chime in.
I would approach it with care and minor adjustments until you achieve what you want.
Just try it.... Easy to change back.
Or, you could raise the rear ride height and achieve similar results with the added benefit of higher COG helping with tip in.
Here is a good book on the subject:
  • I’d also check your tire pressure and condition. The
[/URL]
Ed, you never want a high COG on anything with wheels.....
Yes, it tips in easier, but it is way harder to reverse direction too
Lower the front end instead, that lowers the COG making it even easier
Think about it .... If the COG was 12" off the ground it would totally flickabl
regardless (to a point) of the steering angle
