1 - 3 of 3 Posts
All of a sudden my transmission started acting up. It wouldn't upshift or down shift unless I barely pressed down on the shift pedal for an upshift before shifting again or barely up for a downshift. I also could not hit neutral no matter what I did. Please help.
Thanks, Arizona Brutale
Sounds a bit like the gearshift return spring has had enough, read bit through this section and have a look in the tech tip section, it's a topic which pops up every now and again.
1 - 3 of 3 Posts
