Hi friends:
I´m going to try taking appart my F4R rims. :jsm:
I have a doubt. To unscrew the nuts, must I push to the left or to the righ hand (clockwise direction)????????.
In the rear wheel, I think it is clear because the torque is showed in the rim and the direction.
But, the front wheel nut no. :f4:
Could you help me??
Thanks mates.
Front wheel nuts, i.e. the fork leg bottom bolts are conventional right hand thread. You are right, the rear wheel nut (single large nut) is a left hand thread.Torque setting is 220 - 240 N/m. Use a proper fitting socket on the rear wheel nut and make sure you torque both front and rear correctly when re-fitting. n.b. it's easy to overtighten the fork leg bolts so be careful! Torque setting for front bolts is 20 - 22 N/m :)
we offer a new tool which will fit rear and front (R Models + Tamburini)
it is a 2 in 1 tool fits on any 1/2" ratchet, perfect Quality and Finish guarantied.
rgds
diego
And the front wheel axel???. I am talking about the R. Right hand or left hand thread?.
Thanks for your help.
Sorry Ignacio, I forgot the R set up was different to the S, :cross: please ignore what I've said about the front wheel torques, those figures are for the S. As I don't have an R, perhaps one of the R or Senna 1000 owners can help you out with that info. :)
Anyway, thanks john.
How much is this tool?
rgds
diego
:f4: Diego how much would this tool cost me? I live in the Uk.
