Hi all,
Just come round to fitting the new throttle tube to my Stradale but I'm stumped. The new throttle appears to have a different type of connector - a slimmer one.
Am I being a bit thick here?
I've attached an image of the old and new below...
Cheers.
Nearest I can figure is it is behind the headlight mount.
Many question arise: Did you remove the original throttle...if so where was the connection? It is a simple matter to follow the wiring. Do you have the manual for your bike?
I have gleaned the following pictures from a Rival manual as I do not have a Stradale manual. The bikes are similar enough that this should get you where you need to go.
This is a possibility:
It is a short cable and must very near the throttle.
Thanks, appreciate that info. Annoyingly there's no manual for the Stradale so I have to make do with the Rivale one; the headlight is the main difference between the two.
In the end I had to pretty much take the whole headlight shroud apart to get to it; it was hidden behind the headlight, as you say.
Pita for such a small thing!
