1 - 20 of 27 Posts
2005 F4 AGO 2017 TVL RC
does anyone make guages that do not use mercury for adjusting the air fuel mixture at idle
really?
Ed;
if metallic Mercury is so toxic.......find me the LD50 dosage for it :naughty:
there isn't one for lead either :drummer:
here's a fun list to kill 50% of the lab rats, it takes with;
Nicotine 50mg/kg
Caffeine 192mg/kg
Aspirine 200mg/kg
and metallic Arsenic???? 763mg/kg
so Nicotine is 15+ times as deadly as Arsenic :jsm:
everyone with "silver" fillings has Mercury in their mouth:naughty:
I'd like NIH, CDC or Merck data please
Carbtune
I have the Carbtune set up and it is a quality product for the price
Ed;
Nicotine 50mg/kg
Caffeine 192mg/kg
Aspirine 200mg/kg
Come on Noel....it was tongue in cheek! :stickpoke
Regardless....can't buy mercury filled thermometers anymore either....Kalifornia (again, tongue in cheek) determined they could kill you or cause brain damage if you bit down and broke it in your mouth is my guess.
I used to play with the stuff, we even had bottles of it in high school science labs.....hmmmm, maybe that explains something?? :wtf:
The good old UniSynch tool......works, but I like seeing all 4 cylinders at one time.
I have a pound of Mercury and the old school carb sticks.....rock on Dain Brammage!
Ed;
Nicotine 50mg/kg
Caffeine 192mg/kg
Aspirine 200mg/kg
http://www.atsdr.cdc.gov/ToxProfiles/tp46.pdf
again Tim; what is the LD50 for metallic mercury
a person consumed ~120gr of metallic mercury and lived.....
there isn't one for lead :drummer:
Discussion Starter · #14 ·
used the carbtune setup and did the throttlebody sync. Was already pretty good and the sync did nothing to help the surging. So anyone got any ideas on how to get rid of the oscillating rpm at idle.
Check for vacuum leaks and have the ECU Dyno tuned.
What's the idle speed? Not from the tach on the meter, from an accurate source like the diag software?
i have the motion pro tool, which i haven´t use in a long time. when i tried to use it i found that the blue liquid had dried up. does anyone know if there is something else i can use in it?? any other fluid?? it will take a long time to get the replacement from motion pro, i am in Peru.
Co at idle helps dramatically to fix hunting. You must adjust fuel trim using software.And if someone did your valves before you they could have dropped a tooth and you will never stop it hunting,how do i know i did it once .
cheers eddy
nicogc...contact Motion Pro. They should have replacement fluid. Since that fluid evaproated, it is probably water or alcohol with a coloring agent.
The fluid matters as the device is calibrated for that fluid specific gravity.
any chance the fuel is bad? I've been burnt so many times with today's crappy fuel its the first thing I go with.
1 - 20 of 27 Posts
