1 - 3 of 3 Posts
Does MV sells thermostat that opens at a lower temperature range than standard?
This might help cool the engine abit in traffic...hopefully.
There's a slight problem in the way the MV measures the temp that is displayed on the dash, whereas the ecu engine temp is derived from the sensor in the cylinder head, the dash one comes from a sensor in the LH radiator head tank, so I presume that the colder the weather the colder the rad and hence some heat disspersion away from the rad mounted sensor and a lower than "actual" displayed or "real" engine temp :)
1 - 3 of 3 Posts
