1 - 16 of 16 Posts
Had a forum member alert me of these. Thanks Al. The wife is not so happy with you.
They come in at 234 grams each and look great. Just need to get some Ti bolts, the pin made, and some spacers since these are for the stock 58mm forks.
You're sick. And Al. He's just an enabler. >:)
Just when we think you can鈥檛 go any further...
Reactions: R1andrew
Let me know about the pin for these Andrew. I installed them on my bike with the pin from the OEM clip ons. It works, but just a little too short.
I will either have a pin made or use a Ti bolt. Am I correct in that the bolt which you tighten down is a M7?
The OEM pin works fine, the top nipple part locks it into the top piece, that is what keeps them from rotating. It just isn't long enough to stick out of the bottom and get the circlip on it. Really, it's not necessary, as it has nowhere to go, but if you find someone that can make something, I would be interested in a set
Reactions: Nitro69
The only way I know of to keep myself from buying some of these rare parts is to convince someone I know to buy them first. Same seller has a NOS crc billet upper triple btw
Reactions: Nitro69
Got my ti bolts in and the spacers Al made me. Last night I was able to work on the project for about an hr instead of sleeping. I did add 30 grams vs the old clip-ons, but it is worth it. These just look incredible and flow with the lines of the bike. First pics are of the old ones and the last pics are the new clip-ons. I did have to do a little modifying to the units and the triple clamp. It was a very fun project.
Forgot to mention that since I was ordering bolts. I went ahead and got some ti banjo bolts to replace the ones I am using. This way they will match and are ti and not steel.
I ordered a M6 ti bolt. Drilled out the top and middle sections on the clip-on. Then threaded the bottom. Tighten the bolt just enough to place a little tension on it. Like you said. The triple clamp holds the pin in, and in my case would hold the bolt from backing out.
Discussion Starter #16
Al made me a set.
1 - 16 of 16 Posts
