1 - 2 of 2 Posts
This is mostly directed at 1st Gen MVs, somethings will apply to 2nd Gen
Each line in red is a direct link to the subject.....more are coming!
You have a modern MV Agusta, '99 or later?
The 1st thing you need to do is peel the sticker, that says 28-32 Nm off the swing arm and retorque the
pinch bolts to 15lbft/20Nm
>The BEST oil filter for a 1st Gen MV
http://www.mvagusta.net/forum/153-general-maintenance-tech-issues/236226-best-oil-filter-1st-gen-mv.html
https://www.mvagusta.net/forum/20-maintenance-tech-issues-all-4-cyl-models/242883-why-you-use-purolator-pl-14612-oil-filter.html#post2583355
>How to lock the rear wheel with no drama!
http://www.mvagusta.net/forum/153-general-maintenance-tech-issues/235714-how-lock-rear-wheel-no-drama.html
>Changing the pads in Brembo 4 pad calipers without dealing with springs and clips
https://www.mvagusta.net/forum/153-general-maintenance-tech-issues/244717-4-pad-brembo-pad-changing-easy-way.html
>How to lock the crankshaft to work on the top end!
http://www.mvagusta.net/forum/153-general-maintenance-tech-issues/236474-how-lock-crankshaft-work-top-end.html
> How to lock the cam chain so it won't jump teeth!
http://www.mvagusta.net/forum/153-general-maintenance-tech-issues/235706-how-lock-cam-chain-so-wont-jump-teeth.html
>How to keep the Fuel Line on the fuel pump plate!
http://www.mvagusta.net/forum/153-general-maintenance-tech-issues/235978-how-keep-fuel-line-fuel-pump-plate.html
>How to get rid of most of the lines in the tank of a 1st Gen F4
https://www.mvagusta.net/forum/20-maintenance-tech-issues-all-4-cyl-models/242655-f4-tank-cleanup-simplification.html
>1st Gen Brutale helmet lock
http://www.mvagusta.net/forum/13-brutale-b4/235322-1st-gen-brutale-helmet-lock.html
>Zipper pull repair
https://www.mvagusta.net/forum/26-riding-gear-tools-equipment-accessories-etc/242311-broken-zipper-pull.html
>Marking the speedo sensor and side stand switch plugs so you don't blow a fuse
https://www.mvagusta.net/forum/153-general-maintenance-tech-issues/241869-wiring-harness-trick-1st-gen.html#post2570623
>1st Gen Brutale tail tidy with LEDs
https://www.mvagusta.net/forum/13-brutale-b4/241871-1st-gen-brutale-tail-tidy.html
>Repairing tires on the road
https://www.mvagusta.net/forum/56-suspension-brakes-tyre-tech/244327-lucky-man-maybe-not.html
As always your wealth of knowledge is invaluable, thanks for these M8 the helmet lock has been a fab addition to my Brute!
1 - 2 of 2 Posts
