1 - 6 of 6 Posts
The bike is leaking a little coolant when I park in the paddock.
There is still a bit left until I'm down on min. Is this a problem, or??
leaker?
no problem, Glenn just run it at 'min'
:f4::brutale:
Thank you for your quick response.
The message was posted after the first run group. Before the third, I am reassured.:)
A lovely day on the track. First time on our new track Rudskogen after rebuilding.
And my first knee slide.:ahhh::ahhh::ahhh::ahhh::ahhh:
:f4::brutale:
I had the same thing happen. Brute's coolant level prefers to run toward the min, not the max level. No issue, as long as the temps within normal range
One thing to keep in mind. If it continues to leak and gets low, you probably have something stuck in between the coolant cap's rubber gasket and the mounting flange. You can wipe it clean carefully (of course after it is cool) and wipe the gasket. Mine did this one time.
No problem mate, just don't let it go far below min. It's a "Brutale issue" :confused:
1 - 6 of 6 Posts
