I'm about to fit some 4w LED indicators to my 910s in place of the original 10w globes. Does anyone know what value resistor I would need to use in parallel to simulate the the 10w globe still being there.
Your help is much appreaciated.
Thanks for the reply James. Did you gain this knowledge through the same experience or are you adept at electronic calculations?
Cheers.
Same experience. For me though I took awiner's advice on here and fitted a different relay rather than deal with the resistors. I know that value works however and unfortunately the Brutale takes care of the turn signal relay within the ECU so you can't swap relays like an F4 would.
EDIT: This is probably a good place to add that although all of my coworkers and almost everyone in my building are EE's I am most definitely not adept at electronic calculations without a lot of thinking and double checking :laughing:
