Are there any issues if I swap the rear sprockets (and chains) between an '08 Brutale 910s and 2005 F4 1000S? They should fit, respectively, right?
Thanks in advance.
Aren't the swingarms and wheels the same? I would think it is a direct swap...chain length may be an issue due to different size gear ratios (number of teeth front and back)?? I haven't looked.
That's what it looks like to me but I was trying to confirm it. I am actually going to swap chains as well for two reasons - 1) because they're probably worn in with the sprocket and 2) for the length to match the sprocket size.
Thanks for the response, btw.
