1 - 10 of 10 Posts
2021 Superveloce 800, 2002 RC51, 2008 E90 M3, 1974 Crosle 32F, some SUVs
I just removed the fairing for first oil change. It took me enough head-scratching to figure out which screws to remove, I thought I'd post it here in case anybody else finds it useful. It's actually a very easy fairing to remove, considering how buttoned up the thing looks.
Only need a 2.5 mm and 4 mm allen
1) Remove these 3 cap screws on the top, side of fairing
482999
2) Remove the headlight bezel and the screw screws holding the fairing which are behind the bezel. Here, the screw has already been removed on the right side of the bike. There is a little pin that keep the fairing from falling off until you slide it forward.
483000
3) Remove the screw under the headlight - one screw holds on both sides:
483003
4) Remove only these three screws on the windscreen brace:
483005
5) Remove the screws behind the front wheel, above the oil cooler
483001
6) Remove the three quarter turn fasteners under the oil cooler:
483002
7) Remove the cap screw in the black plastic air escape vent:
483004
8) Now, grab the section right under the tank and pull it out. Rubber grommet thingy, it just pops off. Slide the fairing forward and it will come off the pin by the headlight. Pull the whole thing off slowly and you will have plenty of slack to disconnect the turn signal. I was able to do the connector with my thumb nail but could use a small screwdriver too.
483006
483007
9) The metal lower portion is dead easy, two screws and a quarter turn (not shown) underneath:
483009
10) Repeat for the other side, reverse to reassemble
Dude, you are my hero. I was about to embark on this on my own. MV did such a good job of making it look polished that fairing removal did not seem intuitive compared to all the other bikes that I have owned.
This is a great write and very detailed. I have a flat battery and I am trying to access the posts that allow me to jump the battery without taking the fuel tank off. Is there any way to just remove the silver fairing on the right hand side? Or has to be whole assembly as pictured?
Welcome to the family @mmp !!! You have a SuperVeloce? Where are you in these United States? You can answer those questions with an introductory post in the "New Members" section......
If you have a "flat" battery that will not recover to start your bike by being connected to the charger supplied with it, then that battery is toast. Might as well buy a new one (don't cheap out) and replace....and keep it connected to a smart charger when not riding. MV's are notorious for killing batteries that are not maintained. That's why they provide a charger with every bike.
1 - 10 of 10 Posts
