1 - 11 of 11 Posts
Banned
Met these guys at Barber Motorsports and wanted an adjustment on my F4's suspension. During the setup and dampening settings I noticed they were having some issues and the bike seemed to wallow around a lot when they were doing the bounce test. It was suggested that I overhaul the forks and rear shock as well as change out the spring in the rear (was out of range for sag). They kept the bike overnight (and stayed up until 3am to finish it) and it was ready the next morning for the first session. They had a lot of knowledge about the F4 and even had a few specialized tools. For the quality of work that was done the price was quite reasonable.
Before bringing them the F4 they did work on my R6 which completely transformed the way the bike handled. The F4 was very much the same level of transformation. Worth every penny.
Banned
Nice! We should swap MVs on a ride soon :D
Maybe a really short ride. :) Not sure I could deal with the anxiety of riding a one of 300 limited edition bike and having someone else on my Diamante at the same time. Especially if you end up in front and I have to watch. :ahhh:
It's a real dangerous thing too. Last time I swapped it was on a friends FZR400 and I went and tracked one down and bought it shortly afterwards. :f4:
I'm really looking forward to seeing how it does on the street which is where I normally like to ride it. All this humid rain stuff has been simply awful. :/
Banned
Got out for a quick run on the streets earlier. The difference is pretty staggering. It handles bumps much more effectively now but is not too jarring. It seems to turn in quicker and not seem as heavy as it used to. Might have something to do with the different profile on the new tires. In any event. Money well spent.
RCHACE most riders who upgrade suspension only do so to the rear shock. Truth of the matter is upgrading the front suspension/forks produce a much better handling machine. When to balance both the Front & Rear suspension as you have done,it can turn a ill handling beast into a slick track day bike.
Point being if someone wants to truly improve a bikes handling BOTH front & rear suspension has to be done and correctly tuned . Smart move on your part
Superbike has set up my track bike and my F4. They will always tell you to send in your forks and shock for an overhaul. Then I had to remind them my Ohlins rear was brand new worst thing it needed was air servicing. other than that they really do a great job. and I do track my 312R occasionally so it did improve handling all the way round.
They set up my track bike too. Ken at Superbike Suspension really knows his stuff.
Ws2 welcome to the site and nice to hear from you again Italia . I too own a F4 312R. Just wanted to let you know I had GRIP ONE PRO 2 Traction control/wheelie control unit installed and it works EXCEPTIONALLY well. Head and shoulders above the Bazzaz traction control and any factory units My team rider has tested before . The downside is the unit is a pain In the ass to install but well worth the effort .
Being 6ft4 270lbs My suspension would have a tendency bottom, or near bottom out over medium size bumps. I then had JRI 30mm Fork Cartridges and a Nitron Triple adjustable rear shock with hydrolic preload adjuster and Nitrons optional heavy duty spring. ( BTW NITRON ACTUALLY ADJUSTS SPRING & VALVING TO WEIGHT . Many companies ...Weight adjustment.. is spring only) Transformed MY F4 312R Handling, especially when riding over a bump/swale tipped over mid corner. Even then the suspension follows the surface smoothly and does not disrupt chassis.
I WANTED to get BOTH JRI Cartridges and REAR shock. JRI is the new hot suspension set up in USA.
The JRI rear shock uses new tech/high pressure/large piston like PENSKY RACING but at a lower cost .
JRI has a sale going on 2195$ for BOTH fork cartridges AND high pressure triple adjustable rear race shock.
I CHOSE to use the NITRON RACE SHOCK because of my size/weight. The JRI high pressure race shock has 50mm piston yet is small in physical size. I was leary of bottoming out rear with my 270lb weight .
FYI= The JRI fork cartridges and rear race shocks are made to fit MV AGUSTA F4 1000R/F4 1000RR & MV AGUSTA F3 675R/800R.
CALL JRI, they have more shocks/fork cartridges than on website. http://www.jrishocks.com or USA distributor 856-935-0366
NITRON Triple Adjustable Rear Shocks are made to fit MV AGUSTA F4 1000R/RR F3 675R/800R & BRUTALE models But CALL NITRON , they have MORE shocks than shown on website http://www.nitron.co.uk and factory phone number ...just remembered.. UK DESIGN CORSE a site Supporter sells NITRON . I GET NO MONEY , PARTS ECT FROM POSTING MY EXPERIANCE USING PRODUCTS . I JUST LIKE TO HELP FELLOW MV AGUSTA OWNERS/RIDERS AND TRY TO USE OUR SITE SUPPORTS PRODUCTS I have tried most every well known suspension/braking product on the market . I post GOOD products, I do not post up the BAD/MEDIOCRE Products as I do not like to Bad Mouth a product. (sometimes if REALLY a crap product that advertises its great . That is Rare.
Sorry could upload both pics this is JRI high pressure triple adjustable rear shock with 50mm piston.
JRI is the hot set up in AMA superbike racing right now .
PENSKY RACING uses same high pressure tech but JRI same quality lower cost.
The high pressure in a small shock/big piston has quicker rebound so the suspension follows the BACK SIDE of a bump/swale instead of passing OVER it .
NITRONS Triple Adjustable rear shock with hydrolic preload .IMHO NITRON SHOCKS =EQUAL(many times better quality) ANY TOP TIER SUSPENSION MANUFACTURES PRODUCT AT 40-50% LESS COST .ALSO= They build shock to your weight with Spring AND Valving.
BTW NITRON makes Spring in BLACK color if asked. I ordered BLACK Spring for my MV F4 312R looks great . Used NITRONS traditional BLUE Spring on my Triumph Sprint ST 1050 . Also looks great .. (don't laugh too hard, My Triumph Sprint ST 1050 is my 2rd favorite bike out of 15. Not the fastest bike on the road but SO EASY to ride fast your Grandmother could do a hot lap on one LOL) Tied for favorite =Modified 2007 MV AGUSTA
F4 31R & ROEHR 1250sc . ROEHR 1250sc is an American Superbike using a Harley Davidson Liquid Cooled V-twin V-Rod engine with ROTRAX Super Charger.
1 - 11 of 11 Posts
