1 - 12 of 12 Posts
Hi All,
I'm in need of some assistance.
Sometime after the latest map update at the end of October/ beginning of November 2015, I have noticed that my bike's engine sound sometimes has an irregular cadence at lower RPM. This is coupled with irregular power delivery mostly in the form of random power loss, then a surge.
For example, while in first gear, if I try to hold steady at around 25mph, the engine seems to get into this rhythm audibly where the firing is closer together than expected, almost machine gun like. This happens in second gear around ~35mph also.
Its a bit hard to describe. I will see if I can get some video/audio of it at some point in the next couple of days.
The only modification to the engine is FM Project slip on exhaust.
This didn't happen until recently. I can't recall if it happened at first after the map update or not, so its possible it could be map related or something else.
Any advice would be greatly appreciated.
Thanks,
Michael
I have a habit of missing replies, so I'll explain:
Reason I ask is because the map can determine what your throttle response will be. This is in regards to the noise issue you talk about. TBH, I wouldnt attempt to hold 25mph steady in first gear. The only thing that gear is good for is acceleration. Instead, try slightly lower revs in 2nd.
The slightest movement on the throttle is over exaggerated at those speeds in first and she will get upset/confused on whether you want to accelerate or decelerate. Maintaining a speed is unheard of to her loool
Regarding the surge, I'd say check your TC; it may be the culprit. The delay in power could be due to a high TC setting. Best to test that first and foremost
The TC works off of an algorithm read by the ECU. Engine speed + Rear wheel slippage= TC intervention. It's a very basic system,I'd be surprised if this has anything to do with what your describing.
Did you fit the slip-on before of after the map update? If it was after, then things went bad, why not try putting the old exhaust back and see what happens?
Whenever you change something like a slip on, it does change how it runs. The ECU doesn't recognize this type of change, so no fuelling correction is made.
If you determine that it's the slip on, you can re-fit then get the bike dyno tuned.
Mine had a similar thing before I tuned the throttle bodies. Sounded like wuh wuh wuh wuh and sometimes it would stall when you closed the throttle.
Hi Kag,
Thanks for the response.
My current map is the update from fall last year. I am not sure if a newer one is available as my dealer doesn't let me know.
I don't believe this is a twitchy throttle case. I totally understand where you are coming from. I am quite sensitive to the twitchy throttle as I came from a Daytona 675R which was not drive by wire. It has taken some time to work on riding smooth at lower speeds. I believe the underlying cause is something else.
I have tried different TC settings, and the issue is present regardless of the TC setting.
-Michael
Hi Matt,
I don't believe it is the TC either. My TC setting does not make the issue worse or better.
I have had the slip on basically from the start of ownership. I had the stock map when I picked up the bike, then the map updated last year in the fall. I don't believe the timing of this issue corresponds to the map update, but I could be wrong as I don't remember exactly when it started. I did not have this problem before with this slip on.
-Michael
Hey Jono,
I had the throttle bodies checked at my first service and adjusted, but that was mid last year. I guess its possible that they would need to be adjusted again.
I haven't had any issues with stalling with a closed throttle.
I have had issues of losing power when making slower turns (think making a right after stopping at a stop sign). This is rare, but sometimes happens, and I'm not sure if it is related.
-Michael
Why not take it to your dealer, you should still be under warranty for a 2015?
It could be a TPS, or some other adjustment .
I am planning on taking it to the dealer, but just thought I'd ask on here to see if anyone else had the same problem. Thought it may have been a simple fix or something obvious that I was missing.
-Michael
1 - 12 of 12 Posts
