1 - 3 of 3 Posts
Apologies if this problem has already been mentioned.
I have only had my 2nd hand Serie Oro for two weeks & have done just a few small trips.
Today with my full leathers on, new AGV Corsa helmet I was ready to set off for the NorthWest 200 (Northern Ireland's biggest road racing event)
My Oro was ticking over nicely, when I put it in to gear about to set off all the Dash information disappeard/reappeared etc.
I switched the bike off & turned on again with the fault:
"Stop Eng, Phase sensor" :banghead:
Any info would be helpful on this as the Bike shop never bothered phoning me back :(
Hi Jonathan,
I had a similar error once on my F3 675, happened while riding and the bike would no longer start. It turned out that a intake valve was faulty from the factory. MV ended up replacing the whole engine in my case. But I would assume replacing the defective valve would have been enough.
I would have the bike checked by your local MV dealer, they should be able to identify the issue.
Best regards,
Mike
Hi Jonathan,
Best regards,
Mike
Thank you Mike for the advice & info, apologies for the late reply.
I was fortunate enough! It was a Battery issue, not holding it's charge & had a new one fitted yesterday. So far no further issues.
Lack of life in the battery was bringing up other faults on the dash!
Hopefully now I have a hassle free Summer :f4:
1 - 3 of 3 Posts
