1 - 3 of 3 Posts
Washing the F3 after covering 400miles today. Switched her on to help dry the fragile stuff out properly and I note that the brake light is on.
Trace it to the front brake switch - removing the wires from the front switch and the light goes out - so I remove the switch from the lever assembly and have a look - put it all back together and it is all working ok - so all I can think of is a sticky brake light switch. Anyone else seen this?
Do you have aftermarket levers?
A brake light switch is a simple and fragile device. Clean it with contact cleaner and it should be fine.
I've got an aftermarket clutch lever - but kept the brake stock.
I've cleaned it up and it all seems fine.
Thanks again.
M
1 - 3 of 3 Posts
